C#连接Oracle 11g 无需安装Oracle客户端
2018年7月17日 18:4 本文热度 8779
1.首先到Oracle网站上下载ODAC
下载地址:
附件:ODP.NET_Managed_ODAC12cR4.zip
2.下载的文件解压后找到Oracle.ManagedDataAccess.dll
3.将DLL文件拷贝到你的项目目录下,并引用进来即可
4.测试代码如下所示
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using Oracle.ManagedDataAccess.Client; //加入引用
using Oracle.ManagedDataAccess.Types; //加入引用
namespace ConnOracle
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
         public void ConnOracle()
            try
                string connStr = "User Id=userid;Password=userpwd;Data Source=(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=192.168.1.1)(PORT=1521)))(CONNECT_DATA=(SERVICE_NAME=myDB)))";
                using (var conn = new OracleConnection(connStr))
                    conn.Open();
                    DataSet ds = new DataSet();
                    string sql = "select *  from user.testtable";
                    OracleDataAdapter oda = new OracleDataAdapter(sql, conn);
                    oda.Fill(ds);
                    DataTable dt = ds.Tables[0];
                    dataGridView1.DataSource = dt;
            catch (OracleException ex)
                throw new Exception(ex.Message);
         private void button1_Click(object sender, EventArgs e)
            ConnOracle();
该文章在 2018/7/17 18:04:41 编辑过
