[点晴永久免费OA]C# 使用NPOI 实现Excel的简单导入导出
2020年4月3日 22:36 本文热度 5965
private void btnImport_Click(object sender, EventArgs e)
      DataSet ds = new DataSet();
      DataTable dt = null;
      OpenFileDialog sflg = new OpenFileDialog();
      sflg.Filter = "Excel(*.xls)│*.xls│Excel(*.xlsx)│*.xlsx";
      if (sflg.ShowDialog() == System.Windows.Forms.DialogResult.Cancel)
          return;
      FileStream fs = new FileStream(sflg.FileName, FileMode.Open, FileAccess.Read);
      NPOI.HSSF.UserModel.HSSFWorkbook book = new NPOI.HSSF.UserModel.HSSFWorkbook(fs);
      int sheetCount = book.NumberOfSheets;
      for (int sheetIndex = 0; sheetIndex < sheetCount; sheetIndex++)
          NPOI.SS.UserModel.ISheet sheet = book.GetSheetAt(sheetIndex);
          if (sheet == null) continue;
          NPOI.SS.UserModel.IRow row = sheet.GetRow(0);
          if (row == null) continue;
          int firstCellNum = row.FirstCellNum;
          int lastCellNum = row.LastCellNum;
          if (firstCellNum == lastCellNum) continue;
          dt = new DataTable(sheet.SheetName);
          for (int i = firstCellNum; i < lastCellNum; i++)
              dt.Columns.Add(row.GetCell(i).StringCellValue, typeof(string));
          for (int i = 1; i <= sheet.LastRowNum; i++)
              DataRow newRow = dt.Rows.Add();
              for (int j = firstCellNum; j < lastCellNum; j++)
                  newRow[j] = sheet.GetRow(i).GetCell(j).StringCellValue;
          ds.Tables.Add(dt);
  private void btnExport_Click(object sender, EventArgs e)
      SaveFileDialog sflg = new SaveFileDialog();
          return;
      //this.gridView1.ExportToXls(sflg.FileName);
      //NPOI.xs book = new NPOI.HSSF.UserModel.HSSFWorkbook();
      NPOI.SS.UserModel.IWorkbook book = null;
      if (sflg.FilterIndex == 1)
          book = new NPOI.XSSF.UserModel.XSSFWorkbook();
      NPOI.SS.UserModel.ISheet sheet = book.CreateSheet("test_001");
      // 添加表头
      NPOI.SS.UserModel.IRow row = sheet.CreateRow(0);
      int index = 0;
      foreach (GridColumn item in this.gridView1.Columns)
          if (item.Visible)
              NPOI.SS.UserModel.ICell cell = row.CreateCell(index);
              cell.SetCellType(NPOI.SS.UserModel.CellType.String);
              cell.SetCellValue(item.Caption);
              index++;
      // 添加数据
      for (int i = 0; i < this.gridView1.DataRowCount; i++)
          index = 0;
          row = sheet.CreateRow(i + 1);
              if (item.Visible)
                  cell.SetCellValue(this.gridView1.GetRowCellValue(i, item).ToString());
                  index++;
      // 写入
      System.IO.MemoryStream ms = new System.IO.MemoryStream();
      book.Write(ms);
      book = null;
      using (FileStream fs = new FileStream(sflg.FileName, FileMode.Create, FileAccess.Write))
          byte[] data = ms.ToArray();
          fs.Write(data, 0, data.Length);
          fs.Flush();
      ms.Close();
      ms.Dispose();
该文章在 2020/4/3 22:37:31 编辑过
