[点晴永久免费OA]SQL Server获取数据表字段(表的字段和类型信息)
2021年12月1日 0:6 本文热度 5883
方法一(红色userinf为表名):
SELECT
表名=case when a.colorder=1 then d.name else '' end,
表说明=case when a.colorder=1 then isnull(f.value,'') else '' end,
字段序号=a.colorder,
字段名=a.name,
标识=case when COLUMNPROPERTY(a.id,a.name,'IsIdentity')=1 then '√'else '' end,
主键=case when exists(SELECT 1 FROM sysobjects where xtype='PK' and name in (
  SELECT name FROM sysindexes WHERE indid in(
   SELECT indid FROM sysindexkeys WHERE id = a.id AND colid=a.colid
   ))) then '√' else '' end,
类型=b.name,
占用字节数=a.length,
长度=COLUMNPROPERTY(a.id,a.name,'PRECISION'),
小数位数=isnull(COLUMNPROPERTY(a.id,a.name,'Scale'),0),
允许空=case when a.isnullable=1 then '√'else '' end,
默认值=isnull(e.text,''),
字段说明=isnull(g.[value],'')
FROM syscolumns a
left join systypes b on a.xtype=b.xusertype
inner join sysobjects d on a.id=d.id and d.xtype='U' and d.name<>'dtproperties'
left join syscomments e on a.cdefault=e.id
left join sys.extended_properties g on a.id=g.major_id and a.colid=g.minor_id
left join sys.extended_properties f on d.id=f.major_id and f.minor_id =0
where d.name='userinf'
order by a.id,a.colorder
方法二(红色userinf为表名)
select sc.name as field_id, st.name as field_type from syscolumns sc,systypes st where sc.xtype=st.xtype and sc.id in(select id from sysobjects where xtype='U' and name='userinf') and st.name<>'sysname' order by sc.name;
该文章在 2021/12/1 0:06:38 编辑过
