如何快速比较SQL Server两个不同数据库明细表之间的字段差异
2022年4月22日 10:19 本文热度 8184
用以下几个SQL,可以快速查出两个不同数据库明细表之间的差异:
1、看看两个表的字段数量是否一致:
select count(name) from syscolumns where id=object_id('表名');
2、如果字段数量不同,那么继续用以下SQL获取字段名称和属性,做对比即可:
select name from syscolumns where id=(select id from sysobjects where name='表名')
或者更精确的获取数据类型:
select name as '字段名称',(CASE WHEN type=56 THEN 'int' WHEN type=39 THEN 'nvarchar' WHEN type=38 THEN 'tinyint' WHEN type=35 THEN 'ntext' WHEN type=106 THEN 'datetime' WHEN type=111 THEN 'datetime' WHEN type=108 THEN 'numeric' ELSE 'unkown' END) as '类型',prec as '长度',scale as '小数位',type as '原始类型' from syscolumns where id=(select id from sysobjects where name='表名');
3、比较两个不同数据库A、数据库B相应表的差异(查询表对应的字段是否一致)
  本部分是基于2写的:
select * from (
  select name
  from 数据库A.dbo.syscolumns
  where id=(
    select id from 数据库A.dbo.sysobjects
    where name='表名A')
) T1 FULL OUTER JOIN(
  select name from 数据库B.dbo.syscolumns
  where id=(
    select id from 数据库B.dbo.sysobjects
    where name='表名B'
) T2 on T1.name=T2.name
  例子:
select * from (
  select name
  from Catsic_Compare0803DiLong_2017080311.dbo.syscolumns
  where id=(
    select id from Catsic_Compare0803DiLong_2017080311.dbo.sysobjects
    where name='t_cbjzc')
  select name from Catsicgl_43_2016Eroad_2017111110.dbo.syscolumns
  where id=(
    select id from Catsicgl_43_2016Eroad_2017111110.dbo.sysobjects
只显示字段字段名有差异的字段,增加一个条件即可where T1.name is null or T2.name is null
全部code:
select * from (
  select name
  where id=(
  where id=(
4、生成自定义SQL,增加缺少的字段:
IF NOT EXISTS (select syscolumns.name from syscolumns RIGHT OUTER JOIN sysobjects ON syscolumns.id = sysobjects.id where (sysobjects.name='表名') AND (syscolumns.name='字段名')) alter TABLE 表名 ADD 字段名 int DEFAULT 0;
IF NOT EXISTS (select syscolumns.name from syscolumns RIGHT OUTER JOIN sysobjects ON syscolumns.id = sysobjects.id where (sysobjects.name='表名') AND (syscolumns.name='字段名')) alter TABLE 表名 ADD 字段名 tinyint DEFAULT 0;
IF NOT EXISTS (select syscolumns.name from syscolumns RIGHT OUTER JOIN sysobjects ON syscolumns.id = sysobjects.id where (sysobjects.name='表名') AND (syscolumns.name='字段名')) alter TABLE 表名 ADD 字段名 nvarchar(50);
IF NOT EXISTS (select syscolumns.name from syscolumns RIGHT OUTER JOIN sysobjects ON syscolumns.id = sysobjects.id where (sysobjects.name='表名') AND (syscolumns.name='字段名')) alter TABLE 表名 ADD 字段名 Decimal(18,2) DEFAULT 0;
IF NOT EXISTS (select syscolumns.name from syscolumns RIGHT OUTER JOIN sysobjects ON syscolumns.id = sysobjects.id where (sysobjects.name='表名') AND (syscolumns.name='字段名')) alter TABLE 表名 ADD 字段名 numeric(10, 2) DEFAULT 0;
IF NOT EXISTS (select syscolumns.name from syscolumns RIGHT OUTER JOIN sysobjects ON syscolumns.id = sysobjects.id where (sysobjects.name='表名') AND (syscolumns.name='字段名')) alter TABLE 表名 ADD 字段名 DateTime DEFAULT getdate();
IF NOT EXISTS (select syscolumns.name from syscolumns RIGHT OUTER JOIN sysobjects ON syscolumns.id = sysobjects.id where (sysobjects.name='表名') AND (syscolumns.name='字段名')) alter TABLE 表名 ADD 字段名 nvarchar(MAX);
IF NOT EXISTS (select syscolumns.name from syscolumns RIGHT OUTER JOIN sysobjects ON syscolumns.id = sysobjects.id where (sysobjects.name='表名') AND (syscolumns.name='字段名')) alter TABLE 表名 ADD 字段名 ntext;
该文章在 2022/4/23 9:12:37 编辑过
