[点晴永久免费OA]C#获取本地打印机列表,并将指定打印机设置为默认打印机
2022年7月2日 14:15 本文热度 4007
using System;
using System.Linq;
using System.Text;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
namespace Printers
    /// <summary>
    /// Interaction logic for Window1.xaml
    /// </summary>
    public partial class Window1 : Window
        public Window1()
            InitializeComponent();
            InitprinterComboBox(); //初始化打印机下拉列表选项
        private void InitprinterComboBox()
            List<String> list = LocalPrinter.GetLocalPrinters(); //获得系统中的打印机列表
            foreach (String s in list)
                printerComboBox.Items.Add(s); //将打印机名称添加到下拉框中
        private void printButton_Click(object sender, RoutedEventArgs e)
            if (printerComboBox.selectedItem != null) //判断是否有选中值
                if (Externs.SetDefaultPrinter(printerComboBox.selectedItem.ToString())) //设置默认打印机
                    MessageBox.Show(printerComboBox.selectedItem.ToString() + "设置为默认打印机成功!");
                    MessageBox.Show(printerComboBox.selectedItem.ToString() + "设置为默认打印机失败!");
LocalPrinter.cs
using System;
using System.Linq;
using System.Text;
using System.Drawing.Printing;
using System.Runtime.InteropServices;
namespace Printers
    class LocalPrinter
        private static PrintDocument fPrintDocument = new PrintDocument();
        //获取本机默认打印机名称
        public static String DefaultPrinter()
            return fPrintDocument.PrinterSettings.PrinterName;
        public static List<String> GetLocalPrinters()
            List<String> fPrinters = new List<String>();
            fPrinters.Add(DefaultPrinter()); //默认打印机始终出现在列表的第一项
            foreach (String fPrinterName in PrinterSettings.InstalledPrinters)
                if (!fPrinters.Contains(fPrinterName))
                    fPrinters.Add(fPrinterName);
            return fPrinters;
Externs.cs
using System;
using System.Linq;
using System.Text;
namespace Printers
    class Externs
        [DllImport("winspool.drv")]
        public static extern bool SetDefaultPrinter(String Name); //调用win api将指定名称的打印机设置为默认打印机
该文章在 2022/7/2 14:15:22 编辑过
