站长网拖拽效果完整Js
2011年3月10日 23:33 本文热度 5965
今天在逛站长网时无意中发现站长工具页(http://tool.admin5.com/)各类工具位置支持拖拽,一时兴起研究了下脚本,下边是D下来的脚本(稍做了修改): [code] 站长网拖拽效果完整Js <script language="javascript"> var Util = new Object(); Util.getUserAgent = navigator.userAgent; Util.isGecko = Util.getUserAgent.indexOf("Gecko") != -1; Util.isOpera = Util.getUserAgent.indexOf("Opera") != -1; Util.getOffset = function (el, isLeft) { var retValue = 0; while (el != null) { retValue += el["offset" + (isLeft ? "Left" : "Top")]; el = el.offsetParent; } return retValue; }; Util.bindFunction = function (el, fucName) { return function () { return el[fucName].apply(el, arguments); }; }; Util.re_calcOff = function (el) { for (var i = 0; i < Util.dragArray.length; i++) { var ele = Util.dragArray[i]; ele.elm.pagePosLeft = Util.getOffset(ele.elm, true); ele.elm.pagePosTop = Util.getOffset(ele.elm, false); } var nextSib = el.elm.nextSibling; while (nextSib) { nextSib.pagePosTop -= el.elm.offsetHeight; nextSib = nextSib.nextSibling; } }; Util.hide = function () { Util.rootElement.style.display = "none"; }; Util.show = function () { Util.rootElement.style.display = ""; }; ghostElement = null; getGhostElement = function () { if (!ghostElement) { ghostElement = document.createElement("DIV"); ghostElement.className = "toolbox"; ghostElement.backgroundColor = ""; ghostElement.style.border = "2px dashed #aaa"; ghostElement.innerHTML = " "; } return ghostElement; }; function draggable(el) { this._dragStart = start_Drag; this._drag = when_Drag; this._dragEnd = end_Drag; this._afterDrag = after_Drag; this.isDragging = false; this.elm = el; this.header = document.getElementById(el.id + "_h"); this.hasIFrame = this.elm.getElementsByTagName("IFRAME").length > 0; if (this.header) { this.header.style.cursor = "move"; Drag.init(this.header, this.elm); this.elm.onDragStart = Util.bindFunction(this, "_dragStart"); this.elm.onDrag = Util.bindFunction(this, "_drag"); this.elm.onDragEnd = Util.bindFunction(this, "_dragEnd"); } }; function start_Drag() { Util.re_calcOff(this); this.origNextSibling = this.elm.nextSibling; var _ghostElement = getGhostElement(); var offH = this.elm.offsetHeight; if (Util.isGecko) { offH -= parseInt(_ghostElement.style.borderTopWidth) * 2; } var offW = this.elm.offsetWidth-4; var offLeft = Util.getOffset(this.elm, true); var offTop = Util.getOffset(this.elm, false); Util.hide(); this.elm.style.width = offW+2 + "px"; _ghostElement.style.height = offH-4 + "px"; this.elm.parentNode.insertBefore(_ghostElement, this.elm.nextSibling); this.elm.style.position = "absolute"; this.elm.style.zIndex = 100; this.elm.style.left = offLeft + "px"; this.elm.style.top = offTop + "px"; Util.show(); this.isDragging = false; return false; }; function when_Drag(clientX, clientY) { if (!this.isDragging) { this.elm.style.filter = "alpha(opacity=70)"; this.elm.style.opacity = 0.7; this.isDragging = true; } var found = null; var max_distance = 100000000; for (var i = 0; i < Util.dragArray.length; i++) { var ele = Util.dragArray[i]; var distance = Math.sqrt(Math.pow(clientX - ele.elm.pagePosLeft, 2) + Math.pow(clientY - ele.elm.pagePosTop, 2)); if (ele == this) { continue; } if (isNaN(distance)) { continue; } if (distance < max_distance) { max_distance = distance; found = ele; } } var _ghostElement = getGhostElement(); if (found != null && _ghostElement.nextSibling != found.elm) { found.elm.parentNode.insertBefore(_ghostElement, found.elm); if (Util.isOpera) { document.body.style.display = "none"; document.body.style.display = ""; } } }; function end_Drag() { if (this._afterDrag()) { } return true; }; function after_Drag() { var returnValue = false; Util.hide(); this.elm.style.position = ""; this.elm.style.width = ""; this.elm.style.zIndex = ""; this.elm.style.filter = ""; this.elm.style.opacity = ""; var ele = getGhostElement(); if (ele.nextSibling != this.origNextSibling) { ele.parentNode.insertBefore(this.elm, ele.nextSibling); returnValue = true; } ele.parentNode.removeChild(ele); Util.show(); if (Util.isOpera) { document.body.style.display = "none"; document.body.style.display = ""; } return returnValue; }; var Drag = { obj:null, init:function (elementHeader, element) { elementHeader.onmousedown = Drag.start; elementHeader.obj = element; if (isNaN(parseInt(element.style.left))) { element.style.left = "0px"; } if (isNaN(parseInt(element.style.top))) { element.style.top = "0px"; } element.onDragStart = new Function(); element.onDragEnd = new Function(); element.onDrag = new Function(); }, start:function (event) { var element = Drag.obj = this.obj; event = Drag.fixE(event); if (event.which != 1) { return true; } element.onDragStart(); element.lastMouseX = event.clientX; element.lastMouseY = event.clientY; document.onmouseup = Drag.end; document.onmousemove = Drag.drag; return false; }, drag:function (event) { event = Drag.fixE(event); if (event.which == 0) { return Drag.end(); } var element = Drag.obj; var _clientX = event.clientY; var _clientY = event.clientX; if (element.lastMouseX == _clientY && element.lastMouseY == _clientX) { return false; } var _lastX = parseInt(element.style.top); var _lastY = parseInt(element.style.left); var newX, newY; newX = _lastY + _clientY - element.lastMouseX; newY = _lastX + _clientX - element.lastMouseY; element.style.left = newX + "px"; element.style.top = newY + "px"; element.lastMouseX = _clientY; element.lastMouseY = _clientX; element.onDrag(newX, newY); return false; }, end:function (event) { event = Drag.fixE(event); document.onmousemove = null; document.onmouseup = null; var _onDragEndFuc = Drag.obj.onDragEnd(); Drag.obj = null; return _onDragEndFuc; }, fixE:function (ig_) { if (typeof ig_ == "undefined") { ig_ = window.event; } if (typeof ig_.layerX == "undefined") { ig_.layerX = ig_.offsetX; } if (typeof ig_.layerY == "undefined") { ig_.layerY = ig_.offsetY; } if (typeof ig_.which == "undefined") { ig_.which = ig_.button; } return ig_; } }; function $(element) { var elements = new Array(); if (arguments.length > 1) { for (var i = 0, elements = [], length = arguments.length; i < length; i++) elements.push($(arguments[i])); return elements; } element = document.getElementById(element); return element; }; function chg(elm){ var inner=elm.parentNode.nextSibling; if(inner.style.display=="block"){ inner.style.display="none"; }else{ inner.style.display="block"; } } var _Admin5_init = function (el) { Util.rootElement = el; Util._rows = Util.rootElement.childNodes; Util.column = Util._rows; Util.dragArray = new Array(); var counter = 0; for (var i = 0; i < Util.column.length; i++) { var ele = Util.column[i]; for (var j = 0; j < ele.childNodes.length; j++) { var ele1 = ele.childNodes[j]; if (ele1.tagName == "DIV") { Util.dragArray[counter] = new draggable(ele1); counter++; } } } }; </script>
标题一
木子屋:http://www.mzwu.com/
标题二
标题三
标题四
<script>_Admin5_init($("page"));</script> [/code]
该文章在 2011/3/10 23:33:13 编辑过
