安装nginx后,nginx -t -c nginx.conf 命令出现 “could not open error log file: CreateFile() logs/error.log failed” 错误的原因
2025年9月1日 10:34 本文热度 2883
网上搜索安装nginx的方法,按照步骤在 http://nginx.org/en/download.html 下载了安装包,并配置了conf/nginx.conf,将nginx的根目录添加进了环境变量path中;
打开命令行,进入 'D:\nginx-1.15.3\conf' 目录,执行如下命令验证配置文件的正确性:
结果提示错误:
​nginx: the configuration file 'D:\nginx-1.15.3\conf/nginx.conf syntax is ok
nginx: [emerg] CreateDirectory() "'D:\nginx-1.15.3\conf/temp/client_body_temp" failed (3: The system cannot find the path specified)
nginx: configuration file 'D:\nginx-1.15.3\conf/nginx.conf test failed
并且运行如下命令:
nginx -t
也是出现错误提示:
nginx: [emerg] CreateFile() "'D:\nginx-1.15.3\conf/conf/nginx.conf" failed (3: The system cannot find the path specified)
nginx: configuration file 'D:\nginx-1.15.3\conf/conf/nginx.conf test failed
百思不得其解,后来在命令行上退出 conf 目录,回到根目录 'D:\nginx-1.15.3' ,如下运行命令:
D:\nginx-1.15.3> nginx -t -c conf\nginx.conf
则显示配置文件正确:
nginx: the configuration file D:\nginx-1.15.3/conf\nginx.conf syntax is ok
nginx: configuration file D:\nginx-1.15.3/conf\nginx.conf test is successful
并且,运行命令:
显示nginx安装正常
nginx: the configuration file D:\nginx-1.15.3/conf/nginx.conf syntax is ok
nginx: configuration file D:\nginx-1.15.3/conf/nginx.conf test is successful
附 nginx 常用命令:
验证配置是否正确: nginx -t
查看Nginx的版本号:nginx -V
启动Nginx:start nginx
快速停止或关闭Nginx:nginx -s stop
正常停止或关闭Nginx:nginx -s quit
配置文件修改重装载命令:nginx -s reload
该文章在 2025/9/1 10:36:43 编辑过
