使用动态SQL语句实现简单的行列转置(动态产生列)
Ccoffee
2015年12月24日 10:4 本文热度 9411
 原始数据如下图所示:(商品的销售明细)
date=业务日期;Item=商品名称;saleqty=销售数量;
-- 建立测试数据(表)
create table test (Date varchar(10), item char(10),saleqty int)
insert test values(''2010-01-01'',''AAA'',8)
insert test values(''2010-01-02'',''AAA'',4)
insert test values(''2010-01-03'',''AAA'',5)
insert test values(''2010-01-01'',''BBB'',1)
insert test values(''2010-01-02'',''CCC'',2)
insert test values(''2010-01-03'',''DDD'',6)
需要实现的报表样式:每一行既每一天,显示所有商品(列)该天的销售数量;
实现的方法和思路如下:
-- 实现结果的静态SQL语句写法
-- 整理报表需要的格式
select date,
case item when ''AAA'' then saleqty when null then 0 end as AAA,
case item when ''BBB'' then saleqty when null then 0 end as BBB,
case item when ''CCC'' then saleqty when null then 0 end as CCC,
case item when ''DDD'' then saleqty when null then 0 end as DDD
from test
-- 按日期汇总行
select date,
sum(case item when ''AAA'' then saleqty when null then 0 end) as AAA,
sum(case item when ''BBB'' then saleqty when null then 0 end) as BBB,
sum(case item when ''CCC'' then saleqty when null then 0 end) as CCC,
sum(case item when ''DDD'' then saleqty when null then 0 end) as DDD
from test
group by date
-- 处理数据:将空值的栏位填入数字0;
select date,
isnull (sum(case item when ''AAA'' then saleqty end),0) as AAA,
isnull (sum(case item when ''BBB'' then saleqty end),0) as BBB,
isnull (sum(case item when ''CCC'' then saleqty end),0) as CCC,
isnull (sum(case item when ''DDD'' then saleqty end),0) as DDD
from test
group by date
静态SQL语句编写完成!
-- 需要动态实现的SQL部分
-- 动态语句的实现
select ''isnull (sum(case item when ''''''+item+'''''' then saleqty end),0) as [''+item+'']''
from (select distinct item from test) as a
-- 这一步很关键:利用结果集给变量赋值;
-- 完成!
declare @sql varchar(8000)
set @sql = ''select Date''
select @sql = @sql + '',isnull (sum(case item when ''''''+item+'''''' then saleqty end),0) as [''+item+'']''
select @sql = @sql+'' from test group by date''
exec(@sql)
-- 删除测试数据(表)
drop table test
该文章在 2015/12/24 10:11:35 编辑过
